What Does Error Code 0x3ec Mean Concerning Windows 10?
I had an old computer, but since it is a 64-bit machine I thought of having Windows 10. While I try to sign in, it says check your connection and try again and displays the code, 0x3ec. All the remote, as well as normal network connections, are proper and the applications are only on Windows, yet I get this error. How can I fix this?
Answered By 30 points N/A #325130
To fix this error, try DISM and SFC.
Run command prompt as administrator. Type the following and press enter after typing in each of them.
“DISM.exe /Online /Cleanup-image /Scanhealth”
“DISM.exe /Online /Cleanup-image /Restorehealth”
After this, exit the prompt. Re-open the prompt as an Admin and type in the command, “sfc/scannow.” Press Enter and restart your system.
You can also try opening Windows Powershell as an administrator. Type in the command, “Get-AppxPackage -AllUsers| Foreach {Add-AppxPackage -DisableDevelopmentMode -Register “$($_.InstallLocation)\AppXManifest.xml”, and restart your computer. This process will uninstall and reinstall all Windows apps that are native to your computer.
Answered By 590495 points N/A #328046
If you are using WaveForms and you receive error code “0x3EC,” try transferring the USB cable to another USB port. The full error reads:
“JtscProgramDvc failed ERC: 0x3EC
Device programming failed.”
Try troubleshooting your connection by transferring your USB cable to other USB ports. If this doesn’t work, try using a different USB cable or buy a new USB cable to make sure the cable is working. If this doesn’t work, try using the System File Checker utility. Press the Windows key then type without quotes “cmd” in the search field.
Right-click “cmd.exe” in the search results then select “Run as administrator” to launch an elevated command prompt. In the command prompt window, type the following command then hit Enter:
sfc /scannow
Wait until the process is complete. When it is finished, close the command prompt then restart the computer. If this doesn’t work, run DISM. Go to Fix Windows Update Errors using DISM for a complete list of operating systems.
Download the program specific to your operating system and run it. The PowerShell command in the previous post is incomplete and may not work.
Here’s the complete PowerShell command. Repeat the same steps above to launch an elevated command prompt. In the command prompt window, type without quotes “powershell” then hit Enter. In the PowerShell window, type the following command then hit Enter:
Get-AppxPackage -AllUsers| Foreach {Add-AppxPackage -DisableDevelopmentMode -Register “$($_.InstallLocation)\AppXManifest.xml”}
When it is finished, close the PowerShell window then restart the computer.
