What does “ET” in WordPress means?
I have just started going inside a WordPress blog and when I open the widgets section I saw some boxes starting with "ET" like "ET Advertisements". Anyone here who can explain to me what it means? Thank you.
Hello Adrian Johnson,
You have asked about ET which stands for Elegant Themes. These themes are supporting tools of wordpress. These themes help the web developer to customize and make web site pages more attractive.
WORDPRESS is a platform where you can make a web site by yourself and it gives you the most opportunity to customize your website.
If you would like to customize your website according to your need then WORDPRESS is the best way to make your site more attractive and SEO friendly.
Elegant Themes will give you the opportunity to customize your site according to your need. Actually every theme is created to make wordpress sites attractive.
It’s a better opportunity for web developer because it helps to save time and money. If a web developer wishes to hire a web designer then it may cost him $20,000-$80,000.
So a big amount can be saved by using some attractive themes like Elegant Themes (ET).
Thanks
Notifications
