I had faced a power cut in my area and as the power came I tried to switch on the whirlpool washer but it just flashes f71 error code. I tried to start it after some time but the issue remains the same. Can you tell me what does f71 mean on a whirlpool washer?
What Does F71 Mean On A Whirlpool Washer
F71 error code in this model of washing machine indicates a communication problem between the control board of the user interface and the central management unit (main management board). These error codes will generally be caused by surges or interference in the electrical wiring. Unplug the power cord from the washing machine to completely disconnect the power supply. Wait 1 minute and reconnect the washing machine to see if the error code is resolved. If the code reappears, there may be a problem with the beam connection, a defective UI control card, or a defective central control unit.
