What does HTC means and its relevant tools?
Which software you are going to use and how best I can use the relevant tools?  In what way I may be helpful and vice versa?  What is meant by htc?
Best Answer by Wastler Markus
Answered By 0 points N/A #91105
Hello Dorababu,
I'm sorry, but I am confused with your question: "Which software you are going to use and how best I can use the relevant tools?  In what way I may be helpful and vice versa?"
Is this in relation to your question: "What is meant by htc?"
Anyway, HTC means High Tech Computer. It stands for the name of the Taiwanese company that manufactured the HTC phones (High Tech Computer Corp.)
Answered By 0 points N/A #91106
Hi Dorababu Surathi,
HTC means High Tech Computer. It is a company that offers mobile phones and tablets. You can check on this website for more information: http://www.htc.com/in/
Currently, most HTC phones are operated by Android OS. But they already have phones that are operated by Windows 8 OS. If you will use an HTC mobile or tablet phone that has an Android OS, you can install applications via Google Play which was used to be called Android Market. This will be pre-installed in your device. Once you open this, you will be prompted for your Google account. Then, you can start searching for apps that you desire to use.
Enjoy!
