What does it mean a tower with two flavors?
Browsing for a tower , I check on Silvertones new tower. What does it mean by tower with two flavors?
Silvertone is offering this new tower in two different flavors both of which share the same internal structure. The cases will offer dual 180mm fans in the front and one 120mm spinner at the rear. They will feature the same improved dust filters as the sugo SG09.
The fan placements do not have any metal grills to increase the air flow and there is a large gap between the front panel and the fans. The motherboard is inverted and the CPU is at the bottom. The motherboard tray is on the left side and there are all kinds of room for optical drives and SSDs
