What does Mac os record audio output do?
What is mac OS record audio output? Does this work by recording and capturing a live streaming audio? If yes, after doing so, does the audio quality suffer?
Hi James,
Mac OS record audio output is a recording audio and capturing streaming audio. If you record sounds in MAC you have to be sure you captured it well and have downloadable application tools for a good quality of your capturing, recording and export live streaming audio. Hope it gives you additional information.
Hey there James,Â
There are several applications available online to help you record while streaming your audio.
A sample of such is SoundFlower its free and easy to use. Regarding the sound quality its superb, it would only record the sound from your streaming audio so its dependent to that, make sure that you're streaming the perfect audio to have perfect recording.
A video tutorial regarding Soundflower is given below, which uses another freeware program to help you directly convert your audio output to any format you wish.
Hope this helps.Â
Waall MikeÂ
