What does this magic spell mean?
Anyone there,
Does anyone know what causes this and how to avoid this in the future? My footage is good and not corrupted. I wonder if anyone knows what is going on. I have all the plug-in necessary for my work. Your help will benefit me a lot. Thanks in advance.
After Effects can’t continue: magic spell failed on a topic.
( 40 $ 10 )
Thanks a lot for any help.
Answered By 0 points N/A #125597
 It is a tool in graphics design or Photoshop. It helps you to select a particular area with same format and give you that opportunity to go and edit that particular area. It is a small file in Photoshop library.
When you install some similar application program in a same time then uninstall one program, this problem occurs. Similar application share similar file they have and uninstall one program can take that similar file with it.
In order to solve this problem you need to install plug-in for magic spell. You can easily find this plug-in on internet. Installing missing plug-in will solve this problem.
