What does Sony SmartWatch do?
It makes browsing easy even on the go with no more fumbling on your pocket. This device gives you the most updated notifications you have on your phone. Not only that you have your watch with you, you can now use the 1.3 inch screen, imagine just 1.3 inch and instantly you would be able to manage and be updated to all your online transactions, know the latest news weather forecasts that easy and trendy.
Uses Bluetooth to manage Droid commands and has a multitouch color OLED display. When using Sony Smart Watch, you have to have your phone with you. Your Sony SmartWatch has been available in the U. S. Since April. It is much easier to use for those who own smartphone running Android 2.1 or higher.
What regular watches do? Just giving the time and date. If you want facebook feeds, tweets and caller id for the phone. Now there is a perfect device for all these aspects. Its sony’s smartwatch. Smartwatch of sony experiences pretty pleasant on the wrist. Its completely comfortable and sporty.
The watch features a 1.3” multi touch color OLED display that has 128*128 pixels resolution. Just connect it by Bluetooth (operating range 0 m / 32 ft ) to any android 2.1 phone or higher you can browse your twitter and Facebook feeds, for typical usage the battery runs for almost 3-4 days and 14 days on standby.
Dear friend,
The features of Sony SmartWatch are given below:
1) Easy-to-use,
2) Ultra-responsive touch display.
3) Finding your way around SmartWatch is super simple.
4) Your world’s just a tap, swipe or press away.
I hope you will enjoy using it. And yes it is quite similar to the accessories of iPod nano. Hope the question is answered.
