I could not connect to my internet connection just this morning. I keep on having at t network error 303. What does this mean and what can I do to fix this? My desktop has a 4 GB RAM and runs on Windows 7 64 bit. Thanks.
What does At t network error 303 mean?
Hi Eleni,
Usually, "Error 303" on the Internet means that this site where you are trying to go is not in function in this time. If on this site has not been set an alternative site than you will see "Error 303" on your computer. You can try to open some other Web page or to try with some other web-browser.
Hi Eleni,
Network 303 error means that there is a defective programming by the vendor of the Web server software. A 303 error occurs when there's a corrupt redirection chain.
For example if the URL you enter redirects to another URL then in turn it directs back to your URL, that's the time the error message will appear. Therefore 303 error will appear when your web server does not return any alternative. To resolve this issue, there two possible ways:
Immediately retry the alternative URL.
Change your web browser. Because some of the site you're trying to enter is working fine. For example one URL works fine with Firefox but not with Safari.
You may ask the assistance of the Checkupdown team. They have a free 90 day trial of their service. They will analyze the underlying HTTP data streams and liaise with respective ISP.
Hope this answers your inquiry.
