Hello Techyv Users and Experts,
I have recently heard about the term extractor universal Borland Delphi. Please explain the term to me. Is this a software if so what it does, how to use install and use it on Windows XP, some review of it and download location to download the file.Â
Thanks in advance.
What does this term extractor universal borland delphi means
Universal Extractor is a program that is used to extract files that are on an archive of any type for example .Zip file an installation program or a .MSI Windows Installer package.
It is however not meant to act as a general purpose archiving program such as WinRAR.
You can download it here and get more information on how to install it here.
Hi Alland Ornad,
From what I know this is a software that was made to extract forms and data modules from executable file (.*exe), that was created from Borland Delphi (composition of binary and pascal codes). Also, since you're looking for the tool will give you the link to it so that you can use the software.
Here:Â http://www.downloadatlas.com/free-to-try-c7bcccb3.html
The purpose of Universal Extractor is to decompress and extract archives or installer. It is designed to support various file formats by utilizing backend utilities. It allows you to extract files any type of archives.
Always remember that it's not used to archive all programs nor it's used to L7-Zip or WinRAR.
Hi Alland Ornad,
Universal Extractor is an installation program zip file (like Wise or NSIS), or even a Windows Installer (.msi) package.
That program is not a general purpose archiving program. This program never replaces WinRAR, 7-zip, etc.
If you download this program click here and how to install the software and more information,
I give you the link.
