What is the easiest method of “import dbf in oracle database” ?
Hello Experts,
I need to "import dbf in oracle database". I found some method but I want the easiest method. I have researched on internet but I haven't found the easiest method of "import dbf in oracle database". So, someone tell me what is the easiest method of "import dbf in oracle database" ? I will be grateful to you. Thanks.
Anthony.
Answered By 60 points N/A #89840
Hi Anthony,
I have searched a lot of possible solution with your problems and I picked one of the best solution that may help you. The answer in the site below would help you solve your problem, else help you find the best solution.
Stackoverflow: Import a dbf File in oracle
Another way to find the best solution is to go to different forums like the one below:
Oracle Forum: Recovering the databases from DBF files
That may also help you.
