Hi I like to create a computerized colander.
I need to know what is the easiest way to that.
I am not expert in software development, but I am familiar with vb.net.
So I like to use to develop the colander.
Can I use adobe flash to create an interface for the colander?
Thank you
What is the easiest way to develop a computerized calendar?
There are many easy ways to create a calendar. Microsoft has provided us with a lot of calendar templates so that we can use it.
You can create a calendar by using controls of vb.net and put them in your form and give it display as you want it. You are easy to go. You can use flash as well or creating it. There are many build in events for calendar. I hope this information will helps you.
Thank you
