What is the easy way to transpose faces of photos
I want to transpose faces of different photos. Some sort of software may help doing it I reckon. Please tell me what is the easy way to transpose faces of photos. Give any software name if possible.
Hi Rachel Grifiths,
I worked on your issue and Try to resolve the issue,then find the best solution for the transpose faces of photos.
There are lot of tools in market but the best tools for the transpose faces of photos are:
You can download any one of them, You can find the online tutorial of all. Now, i am using photoshop and if you are a beginner then you can try GIMP tool, this is very easy to use.Photoshop is a professional tool so you need more skill to work on photoshop.
I hope it may helps you.
Thanks!
Notifications
