What is the effective Anti-Virus?
Dear Roger Neil, the most effective antivirus is the ESET NOD32 antivirus; this has been on the market as the highest ranked antivirus since its inception in 1998. It has been tested among the in -the -wild Virus and has proved to be the best. This was based on its proactive detection ,detecting malicious programs that have not been detected by other antivirus. Its detective engine was designed in such a way that it can detect malware without necessarily basing on the virus updates or signatures. What l mean, it catches the virus depending on its malicious behavior.
Though a number of malicious malware variants have been designed by cyber criminals to defeat the antivirus solutions on the market by failing them to detect the emerging threats from the genuine programs . But ESET antivirus unique sensor technology has been closing this vulnerability gap, showing proactive high detection rate. You can down load it from this link https://www.eset.com/us/home/free-trial/
Good luck
Hi Roger Neil,
The most effective antivirus that I can recommend you is McAfee it is one of the best antivirus software. I am currently using this software right now and it works great for me. There is free-day trial available online. Just try to avail and hope it will help you. Some of its security products and solution are the following:
I hope the information I give you will help you.
Notifications
