I would like to know what an electronic bidet toilet seat is. What are some of the vital features of the electronic bidet toilet seat? What is the concept hovering around the designing of the electronic bidet toilet seat? What are the reasons why the electronic bidet toilet seat be ascribed as a luxury that one cannot do away with? What should be the average price an electronic bidet toilet seat?
What is an electronic bidet toilet seat
Basically, I don't know how do without cleaning your self with water, But electronic bidet toilet seat takes the water washing to nex level, It makes the toilet seat more, So it won't be that cold on these hard cold days, It will also will dry your bottom with warmed air, Once you use it, You won't be able to do without, It seems silly, But after one try you will just hate yourself for using normal toilet seat, The price ranges between $250 to more than $1,700.
