Hi!
I would like to run an email campaign for my online products. I do not have an organized email database but I have emails in different documents in my computer and an external hard drive. Which email extraction software would you recommend for use in extracting all the emails from the folders? What forms the basis of your choice? Thanks.
What email extraction software can extract from files and folders?
Hi dear Hay Lin Lyana,
Thank you for your questions.
You need a email extraction software. Use the following one to solve your problem-
Tools email checker
Actually its not a software, its a online extractor tool. Here find some option by which you can extract data from Doc file as well as a folder.
Hope you enjoy my answer.
Lyana
There are a lot of email extractor software’s that are available in the internet. But I have here software for you. That would locate, organize your emails from different locations, in your computer, documents, local drives, USB or even external hard drive. Just click the link below for you to check out this software.
Click-this-link-for-email-extractor
