What is the email link? how create
How does it work?
Where does it use?
Please tell me about details.
Is email link important to web page?
How does it work?
Where does it use?
Email link is very much important for web page designer or developer.
Email link are normally used in form where visitors send their opinion on the topics.
Here is the example:
<a href="mailto:…….@….com">
send an e-mail to …………</a>
You can put your required word in the dot place.
The e-mail link is one of the important of a website:
Example: If your e-mail address is [email protected], type the following in the Link text tbox:
Add the first parameter:
If parameter, the link information in the Link text box appears as you added this:
Add additional parameters:
With Subject, Cc, and Bc parameters added to the e-mail link, the information in the Link text box is similar to:
Add more than one e-mail address to the Cc or Bc parameter:
Add spaces and special characters:Â
Hello Michele
This is very good question. Dear Michele email link is very important for any registration.
I am describing this topic that will help to understand the email link work.
1. First email link may be many types:
2. When you create a account in any site than admin of site send a code to your email that is password of you account. So Email id or Email link is very necessary.
3. In future if you forget your user name of password than when you click forget my account password than a link will be send to your email id .
I hope this is helpful to you.
Zafar Ali
Hello Michele,
YES EMAIL LINK HAS SO MUCH IMPORTANT IN WEB PAGE
Also to activate your account on any web site you need email ID.
RegardsÂ
