Can you explain in detail exactly what Equus RX PRO is and what is needed to run it?
Will it run on .NET Framework and which version?
Also, how do I find out if I already have .NET Framework installed?
reza81
What is Equus RX PRO and what is needed to run it?
Equus-RX PRO is a very powerful software package. It helps horseman focus on the important things that come with keeping his horse healthy and fit. It is perfect for the horsemen implementing a conditioning and nutritional program for their horses. It is a well-designed and easy to use software package.
You need to install .NET Framework in your system to run Equus-RX PRO software. It will run better on the latest version of the .NET Framework. Now the latest version of the .NET Framework is 1.1. The .NET Framework is a component of Microsoft Windows operating system.
If you already have the .NET Framework installed in your system, you can check it by-
1. Clicking on the Start
2. Selecting Control Panel
3. Double clicking the Add or Remove Programs icon
When that window appears, scroll through the list of applications. If you see the latest version of the Microsoft .NET
Framework, you need not install it again.
If you are using Windows Server 2003 the .NET Framework 1.1 is installed by default.
