Hi, I know that there are some softwares to remove the exif on windows.Among of them,exif tag remover is very easy to use because of its special GUI.But as a mac user, the exif is not the same.So, I need to have a software to delete exif mac.
What is the exact software to delete exif Mac?
The easiest software for removing EXIF data is SmallImage application for Mac. You can download from this link:
https://en.softonic.com/s/smallimage:mac?redirectedFrom=app
smallimage Here you can find It’s a freeware application. SmallImage can remove EXIF from images saved in JPEG format. It’s very simple application tool to batch process JPEG files, with features such as resizing, recompressing, removing embedded profiles etc. If you need application for exif tag deletion the SmallImage is great choice for you!
Williamson Mellisa
