What exactly is dumping MySQL import procedures?
What exactly is dumping MySQL import procedures? If I am dumping some procedures then how do I import data from them?
Using MySQL you can dump the import procedures. This means that you do not need to repeat the same functions again and again.
Once you create a function or a set of functions you can just dump them and then use them as import files later on. If there is another program that needs the same functions or set of functions then you can just import the functions. This saves the time to type the code again repeatedly.Â
You can also store the procedures and strings. Just type the following code to import the procedures:
mysqldump –routines –no-create-info –no-data –no-create-db –skip-opt <database> > outputfile.sql
Hope this information helps you.
