Where is it differing from web browsers? Is it secure to browsing, how? Understand me its secure email features and is it enhanced in privacy? What is CreateHardLink API, it has? Is ASLR system enabled in Sandboxie 4.16? When I am printing PDF of Sandboxie ,then chrome was hanged, is it fixed in the new version? Is there any drag and drop facility? Is there an auto update feature? What is hook and how does this work? What are the new features available in Sandboxie 4.16? Thank You
What is exactly included in Sandboxie 4.16
This is released on 20th February 2015. The major designing hooking code. ASLR is enabled and it is 64 bits. The Version Changes are no longer downloaded and it is 32 and 64 installer.
The version changes DLL's are included in installer binary. The KB 3031432 is used in windows 8 and 64 bit applications.
The sub is now detected and Sandboxed applications start Werfault.exe has crashed, werfault has enough time to create the crash DMP file. The application has crashed will exit and dump cannot create.
The Werfault box and issues and its own SBIE2224: Sandboxed program crashed".
