Hey guys,
The current empty space disk wiper program that I am using (eraser) is just to slow. The last time I ran it, took around two days to complete. I am looking for a faster program and also one that is preferably free or at a low to minimal cost.
What is the fastest empty space disk wiper?
Hello Tony
I know that Eraser is very slow, and it takes quite a lot of time until it deletes files.
It also depends on the capacity of your Hard Disk Drive. However 2 days, is just not worth it.
A better software for your needs, is CCleaner, a very useful file shredder that cleans data left behind by web browsers, windows explorer, temporary files, and other applications. It is also easy to use.
A second software that might help you, is Disk Redactor.
Even easier to use, and if you do not want the free version, you can upgrade it at low cost.
You can download Disk Redactor from Here or CCleaner from Here
I hope you found this information useful.
Randolph
