What is a filter and different types of filter
When passive or active elements are designed to reject or select a band of frequencies then it is called filter. Filters are used to remove unwanted frequencies. There are two types of filter.
1) Active filter: – Active filters are filters that employ active devices such as transistors and operational amplifiers in combination with R, L, and C
2) Passive filter: – Passive filters are those filters composed of series or parallel combination of R, L, and C elements.
Low pass filter: – The filter which passes only the frequencies below cutoff frequencies.
High pass filter: – The filter which passes only the frequencies above cutoff frequencies.
Your Question is not clear; there are many things in which we use filter like in Photoshop, Electrical Engineering, and Water Filter etc. So please describe your question little more.
