What is frame in HTML code?
What is a frame ? When and how is it used? Why do we need it in HTML? Is there any alternative for frame which can
perform the functions of the frame?
Hey Arman Hamilton!
If you want to display more than one Webpage in your single browser windows, then you have to use the FRAME.
Each webpage here is called as Frame. Here is a simple code for Frame in HTML.
<html>
<frameset cols="25%,50%,25%">
<frame src="frame_a.htm" />
<frame src="frame_b.htm" />
<frame src="frame_c.htm" />
</frameset>
</html>
In Frame, you have to give the particular space to each HTML Document. For example in the above code you can see that 25% of the space is given to A, 50% to B and 25% to C.
If you want to know more about the Frame then you can visit this link.
https://www.w3schools.com/tags/tag_frame.asp
I hope it will help u a lot.
Thanks
Frame is used to divide the page into many rectangular areas. The rectangle is called Frame in HTML. Frames are used to keep part of the page stable or fix.
