What Front end applications SQL server to be used?
Hello! I just need help! I am currently into database administration. I want to know what front end applications SQL server should I be using to input data easily? Thank you!
In most situations the front end applications are either tailor made for the customer needs or at times custom made to suit customer needs. In other situations web based front end applications are also used to interact with the database
However, it is easier to provide the customer with a much familiar interface to interact with the database on the backend. This brings developers to using Ms Access or Ms Excel as their front end applications.
Below is a link showing on how to configure Excel to act as your front end application
https://www.lifewire.com/excel-front-end-to-sql-server-2495398
