What is the function of packaging and deployment wizard?
What is the function of packaging and deployment wizard in visual basic 6.0 and where can I use it? It is essential and useful in visual basic 6.0 programming?
The use of VB application only runs when you have Visual Basics installed in your PC. And once you give or send this application to a family members or client, they cannot run this application unless they will buy Visual Studio which cost expensively. This time, these packaging and deployment wizard in visual basic 6.0 come to the rescue. It will serve as an installation package that allows your family member or client to install and run your VB application on his or her PC without spending a penny. In this way, your client will appreciate the free application you give the.
The packaging and deployment wizard is very much essential in the use of visual basic 6.0 programming.
Notifications
