I am just wondering if what is the function for print screen xperia neo? I can’t seem to find the correct function for the specific feature. I need some work to be captured for some reference or proof basis. I hope you can give me the best suggestion, idea or possible solution regarding this matter. Your help will be much appreciated.
The function of the print screen on your Sony phone works exactly like the print screen button on your PC. It allows you take a screenshot and save it to your gallery or use it in a message.
The Sony Ericsson Xperia Neo is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled to the public on February 2011 and released on March 2011 measuring 116 x 57 x 13 millimeters and weighing 126 grams. Unfortunately, this phone has been discontinued.
It uses mini-SIM card and has LED-backlit LCD capacitive touchscreen display with 16M colors at 480 x 854 pixels screen resolution. It supports multi-touch protected by scratch-resistant glass. It runs on Android 2.3.4 Gingerbread upgradable to Android 4.0 Ice Cream Sandwich powered by Qualcomm MSM8255 Snapdragon S2 chipset, 1 GHz Scorpion processor, and Adreno 205 GPU. It supports microSD expandable up to 32 GB.
It runs on 512 MB RAM with 320 MB internal storage. The primary camera supports 8 megapixels with LED flash and autofocus featuring geo-tagging, face and smile detection, touch focus, and video calling. It supports 720p video recording at 30 fps. It has a secondary camera.
It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 2.1 with A2DP support, GPS with A-GPS support, stereo FM radio with RDS support, and microUSB 2.0. It has built-in compass, accelerometer, and proximity sensors. The pre-installed web browser supports HTML with Adobe Flash support.
It runs on removable Li-Ion 1500 mAh battery with standby time up to 430 hours on 2G and 400 hours on 3G. Talk time is up to 6 hours 55 minutes on 2G and 7 hours on 3G. It is available in blue gradient, silver, and red colors.
Now, to take a screenshot on Android 2.3.4, press and hold the Power button then quickly press the Home or Back button. The second button varies between handsets because button placements are not the same in all Android phones.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
