What is the function of Skype?
Why skype free download for blackberry tab in network or internet? After download what will be done? How will it be work?
Hi,Â
Yes Skype is now free to download in Black Berry also and you can download it from various web sites to your cell phones but we are talking here about Black Berry. After downloading Skype just make sure you have an Id of Skype to use on it. If not try to make one and get log in and start using Skype. Skype is basically a modern technology called Voice Over Internet Protocol. You can use it for computer to computer video calls, computer to cell video calls, or cell to cell video calls through Skype. No matter if he or she is not in the country but you can access them by Skype through video calls. Fast and easy way to be in touched with your love ones.
hope the answer for your solution
Hi there,
You can use the Skype application for in many ways, like chatting with your friends that also have a Skype and its main function its video calls and video chat with your online friends on Skype.
After you download your Skype application, you have to install it, just follow the procedure or the instruction in installing it, so you can use it properly.
