What is the function of “undo” command?
Thanks for the question.
The shortcut for undo is : Ctrl+Z
You use this shortcut more often in Microsoft Word. For instance, you are typing an essay and you realized that the paragraph you typed before you erased is the one you want. So just press Ctrl+Z and keep pressing Z until you get wherever you want.
Yes, it is that simple. If In Word, just press the blue arrow that goes to the Left, on the left-top corner.
So basically, this feature is to recover what you deleted.
Remember, if you want to keep undoing, HOLD the CTRL key and keep pressing the Z key simultaneously.
With best regards,
Suaz.
The function of "undo" command is to go back to the previous if in case you have done a mistake when working with any Office Program.
The “undo” command is very important and it exists in almost all applications that requires it. The “undo” command erases or deletes the last change done to the document reverting it to an older state or the state before the last action was done. In several more advanced applications like graphics processing, the “undo” command negates or cancels out the last command done to the file being edited.
The opposite of the “undo” command is the “redo” command which reverses the effect of the “undo” command or advances the buffer to a more current state. In most applications, the “undo” command is activated by pressing CTRL + Z on your keyboard. For the “redo” command, you press CTRL + Y.
Back in the 80s, multi-level undo commands were introduced allowing users to take back a series of actions, not just the most recent one.
