What is the function of windows safe mode?
What is the function of booting windows into safe mode? Why should I choose to boot my laptop into safe mode?
Dear friend,
It is very important to boot your laptop using the safe mode during critical problems that occurs while the computer was still running. The chief function of booting using safe mode is to allow the windows to troubleshoot. It further helps in the determination of problems that can cause the laptop or computer not to function well. Therefore for you to protect all the documents and data contained in your laptop, it is recommended to boot it using the safe mode. After that you can boot it again using the normal booting process. This is because the laptop will have already finished repairing all the problems.
Regards!
Safe mode is a troubleshooting option for Windows operation system. When you select safe mode to star your windows, our windows start with only the basic files and device drivers necessary to run windows. Many malware processes are persistent, auto start with windows and block other legitimate programs from executing.
In such situation booting into Windows safe mode is nothing but disable the problematic processes and provide you with a chance to proceed with malware cleaning. If you feel difficulty to identify the problem creating process, or malware then you can use the process of elimination which will help you to find the problem easily.
Try staring all the programs you commonly use, including the programs in your startup folder, one by one, to see if a program might be the cause of the problem So it is very important to boot your laptop using the safe mode during critical problems that occurs while the computer was still running When you run your laptop, if any critical problem occur then it is very important to boot your laptop using the safe mode. It allows the windows to troubleshoot and further more it help you to determine problematic process or programs that cause the Laptop or computer not to function well.
Windows Safe Mode is used when users was unable to boot on Windows normal mode or could not be able to resolve serious errors in normal mode. It bypasses the entire startup programs that are not needed for Windows to open and therefore it will allow you fix those Windows issues. Safe Mode is a analytical mode on a computer OS. It aims to fix almost all your OS problems. And this is extensively used for eliminating rogue security programs. However, when in Safe Mode, the operating system has lesser functionality. But eliminating problems is simpler since most of the non-core elements are disabled.
Safe Mode are present on the following operating system:
1. Microsoft Windows
2. Mac OS X (Or also called as Safe Boot)
3. Linux Distributions such as Ubuntu or Mint
When in Safe Mode, it normally loads a small number of executables and it normally disable the devices except for some that are needed to show the information and will accept inputs. It usually gives access to the utilities and tools on troubleshooting those that prevents the OS from working correctly. It is envisioned for repairs and not functionality.
