What is the function of WinRescue in Windows 7?
I heard aboutWin Rescue in windows 7 as a backup and recovery tool but dose it has auto save function or I have to set its settings for auto save manually in my computer.
Hello
WinRescue is very good application for making back up of your system and recovering your system from a backup file. It can recover application data, registry, start menu, favourites, control panel etc. You can schedule your back up to some time, for example weekly or daily, it's your choice.
You can download your copy of this application at this link
Regards.
Hello dear,
This is not a new problem. In windows XP, there is a security center, which controls all notifications, like virus alerts, firewall, system updates and other risks to the data or system. On windows 7, the name is changed from Security Center to Win Rescue.
I hope this helps. Everything done by the Win Rescue in 7 is done by the Security center in XP. Thanks.
Notifications
