What is the functionality of free avast toolbar?
Hi Md Raviul Alam vai,
Here you wanted to know about the use of the toolbar of Avast which is free. It has some uses such as if you use it in Firefox for your search bar then it prevents all type virus content which is known to the Avast Center. This is the use of the search bar of Avast which is used as a toolbar. But it has some disadvantage too. Thank you very much.
Hi MD Raviul Alam!
To answer your question, the Avast Toolbar is a set of toolbars which has been developed by Avast software. One main example is the Easy Pass Toolbar which is an Internet Explorer Toolbar. The purpose of this is to make it easier for the users to log-in to their favorite websites and applications.
It is also a very user friendly application since you just need to save your log-in data once using Avast since it will automatically be saved in the database after the first use. Right after you create an online account, you can already enjoy the most convenient way of one click access to your data at the same time having a back up capability in the server.
I hope this helps. Thank you!
If you have an Avast toolbar on your browser, I think it’s the same with the Norton toolbar which alerts you when you visit a rogue website. It is a handy tool on the browser that warns you if the website you are visiting is infected or has been reported as malicious website.
At the moment, I’m not sure if there is still a toolbar like that from Avast. If you want a plug-in for your browser from Avast, what is available at the moment is the Avast Browser Cleanup. It is a browser cleanup utility from Avast antivirus that detects bad add-ons on your browser so you will have a safe browsing experience.
It will only remove add-ons with bad reputations and allow you to use the good ones. Avast Browser Cleanup supports Windows XP Service Pack 3, Windows Vista Service Pack 2, Windows 7 Service Pack 1, and Windows 8.x. It requires Microsoft Internet Explorer 8 or higher, Mozilla Firefox 23 or higher, and Google Chrome 29 or higher.
