What functions does IQsync have?
Hi. I am in search for a programming software.
Can someone give their opinions on the IQsync software?
What functions does it have and would it work on a Windows XP 64 bit system?
Thanks in advance.
Thanks in advance.
The IQsync software copies then synchronizes folders and files to other folders and drives.
This freeware can work very well on a number of Windows including a Windows XP, 64 bit system.
Apart from synchronizing folders and files, the freeware also uploads files on FTP websites.
You can get more information from the paresi.net website.
If you are in search for a programming software then I think iQ-Sync is not the one you are looking for.
Actually, iQ-Sync is not a programming software but a program that simply copies, backups, and synchronizes files and this is recommended for developers.
With this program you can synchronize files with other folders, and drives including USB flash drives. To use it, just setup an infinite number of copy projects and then whenever you want to use it simply highlight the project and then press Run.
Aside from that, you can also configure actions that may run either “Before” or “After” the copy. You can setup different “Actions” such as Run Executables, Delete Files, send FTP files to remote servers, Create Directories, and more. If you want to try this program, you can download the latest version, iQ-Sync 1.46.
It would also help if you’ll watch “How to use IQsync Software development tool video tutorial by TechyV”.
