anonymous
7060 points
Posted on - 08/04/2011
What is FZC in cracking zip password files?
Any suggestion is of great use to me.
harmion
Hi Khusi,
Fast Zip Cracker (FZC) unzips zipped files which are protected with passwords. Just so you know, Zipping is a method of compressing files into one file.
In some FZCs, brute-force attack is used, where the password is cracked using exhaustive key search. Another method, wordlist attack, tests millions of words from a text file archive to find the probable password. FZCs can also retrieve lost password or destroy the password.
I think that’s enough for you. If you want to know more about FZC, then come back and inform us.
