I am getting this error message called “ general error” in the MySQL. Please see image below.
Can you share a solution to this problem. I couldn’t find any answers even after searching the net.
Any help would be appreciated.
Thank you.
General Error
SQL ERROR [mysql4]
Duplicate entry "test1" for key [1062]
An error occurred wide fetching this page. Please contact an administrator if this problem persists.
What is this General Error in the MySQL
The query used for accessing the database is creating problems.
1. The problem is that a key column has broken its integrity that it contains multiple values. The test 1 is duplicate.
2. The programming code may be produced along with the dataset in the database for finding, means debugging the errors.
3. The entire scheme is theoretic. The later is used for such reason. The entirety is done by the programming steps. Either you are using a script of some other version that is installed on the system
4. You can overcome this by structuring the database in a better way.
