I'm looking for a cloud based management solution that is simple to use which I can also run on my Android Froyo v2.3. My pc runs on windows 7 64 bit. Does someone know a simple retail management opensource software?
What is a good and simple retail management opensource software?
Hello Joanna,
http://www.jboss.org/ – FuseSource – This is an open source retail management software for retail. The site also has a forum community for learning and sharing ideas on how to specifically add features to meet your individual need.
www.imongg.com – This is a Point of Sale software that allows you to run hundreds of stores. It also supports web based retail businesses.
These are two open source retail management software that should be to supply your needs. If they do not support your Android, since its open source there is the possibility to code the software to fit your needs.
Winchel Shirlyn
