What is the a good antivirus in terms of small disk usage?
Hello techyv.com!
I'm currently using Karpersky antivirus but it consumes a lot of disk space on my Drive C and I have lots of files in it.
I want to know an antivirus that is best in performance on detecting and deleting viruses as well as a good antivirus small disk space user?
Thanks techyv.com!
Best Answer by Bernard L Jefferson
Answered By 0 points N/A #172493
Hi Albert,
I suggest what I use and that is the Avira FREE Antivirus. I've been using it since lately and for so long.
AVIRA ANTIVIRUS is cool and good.
Many loves to use these antivirus because it was great and good.
It is a fast performing antivirus as I've using it with my desktop and laptop.
You can try and use it as well.
It is a good antivirus and it can clear up the viruses on your computers.
Answered By 0 points N/A #172495
I would recommend you free antivirus which has great performance and keep your system free from viruses.
The Microsoft Essential is a great product of Microsoft t company so download this antivirus in your system.
It has very reasonable space and it will keep your system update.
Now you can use your system without any problem.
The performance is great during the clean of whole system. Go to the Google bar and search for this antivirus for download.
