What is a good auto photo cut software?
Hi there.  I would like to edit a lot of digital JPEG images.  I want to crop, separate the foreground from the background then make a collage out of it.  Can someone suggest an auto photo cut software that can do these?  I'm on Windows Vista 64 bit.  Thanks.
Best Answer by Peter A May
Answered By 10 points N/A #134861
Hi David Aames,
There is many software which will help you to do your work easily. Depend on internet research I am suggesting you a software “InstantMask Pro”. I think it will help you as you want. I am attaching here a link where you will get this software and this is a trial version of this software. Just download this software and try this for is it suitable for your work or not.
Download link- http://clipping-path-studio.com/download/
Here you will get both windows and MAC version, just visit there and download.
Good luck
Answered By 0 points N/A #134862
Hope you would be fine,
Here I am submitting my comments, There are different way to edit the images, but the best way according to my Knowledge is edit the image into Adobe Photoshop or Microsoft Office Picture Manager.
