William Sao
30 points
Posted on - 02/08/2013
I have a dozen .img files that I'd like to burn into a CD. I used Nero 12 Platinum before and the burned images did not come out well. What is a good burn img program that won't touch the quality of the image? I have Asus 24x DVD Burner Sata. Thanks.
What is a good burn img program other than Nero?
Hello Dear,
You can use many software for this purpose, but it depends upon you that you want free software or you want to purchase a software.
If you want to use free software then use “imgburn”, It is the best software for burn DVD/CD for every type of file.
You can free download this software from here.
If you want to purchase software then there is “Clone DVD” software which is best for this use.
Hope this will help.
