What is a good Disk speedup program?
My PC has been sluggish the past few days and I don't know if I need more RAM.  I tried disk cleanup and defragment but still sluggish.  What is a good disk speedup software so I can analyze and optimize disk usage?  I'm on Windows 7 64 bit.  Thanks.
Best Answer by Flinder Matthew
Answered By 0 points N/A #139989
            For better performance or for faster PC I think your problem is your RAM, you must upgrade it or buy a larger capacity RAM because the purpose of RAM is to load and run programs or applications on a computer operating system, more RAM means more Process can be made and also means faster Computer.
Answered By 10 points N/A #139990
Check to see if any unwanted services are running in the background. If so close them. You can view the services by typing services.msc in the Start–> Run command window.
This will improve performance. To better the performance further, defragment your hard disk. This will improve your system performance significantly.
Hope this info helps!
Answered By 0 points N/A #139991
Hello Braxton Fredrick,
By many techniques you can make your PC speedup. I will recommend you to visit a Techyv page which one is contain many techniques regards of this issue.
 Visit " I want to make my PC speedy" and get more useful techniques.
