What is a good motherboard health test software?
Hey guys,
I would like to test the health of my motherboard as I have been having computer problems as of late and it is my opinion that it is a motherboard issue. What is the best motherboard health test software freeware that is currently available?
Answered By 10 points N/A #176603
Hello Robert,
What are problems are you facing? Are you getting hard disk not getting detected errors? Are you facing frequent restarts?
Have you over-clocked your CPU? Did you recently install any new hardware?
At this point in time, there are not many freely available motherboard monitors/ checkers.
I would suggest you should try using "'Motherboard Monitor', it is free and has a comprehensive set of tools which checks your motherboard, however, I would suggest that before using it, you should first determine the make and model of your motherboard.
Hope this helps you identify the problems with your motherboard.
Mclean Buono
