What is a good Performance rating tool xp?
I'm looking for a performance rating tool xp for my PC to run smoothly. My PC runs on i5 2.66 GHz, 4G RAM. Real-time defragmentation is a plus.
Thank you.
Thank you.
There are many utility tool that you can use to enhance your computer's performance. But if you are looking for one that has a real-time defragmentation function, you can try the PC Tools Performance Toolkit. It has lots of features that can help you improve or boost your computer system. It also helps in repairing your registry and disable non-important startup programs. It can also restore your files, delete the history of your browser, optimize your system, and more.
You will need to purchase it or try a free scan from the link below:
Hello Jose,Â
I was having some problems with my PC, too. I was searching for a program that can help my computer smoothly and I think that one of my friends gives me the best solution that can help you, too. The program is called PC Tools Performance Kit. It can run for you with your PC performances. I think that this program will help you for sure.
Hi Jose,
The PC Tools Performance Toolkit is used to de-clutter and streamline your PC. And to do so it will repair invalid registry entries, remove orphaned registry entries, and turn off non-essential startup programs. Other important features are browser-history deletion, system optimization, file restoration, and real-time system monitoring. So have a try with this to monitor your system performance.
Hi Dear,
There are lots of these programs available on the internet. You can download many performance rating tools from the internet. I want to suggest one software that I have used and had positive results with. The name of this software is Advanced System Care. You can download it from this link.
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html
