Can you suggest a good remote software for my computer which is running on Windows? The internet connection I have at my home has a very high speed (60d/5u) and I would like to have a compatible remote software for games and other non-business applications/programs.
What is a good remote software that is running in Windows?
You can try using TeamViewer. For personal use, this is free and it allows you remote access to your personal computer through multiple platforms including Windows, iOS, OSX and Linux. There's an option in this software where you do not need to install anything and still be able to use it making remote access from a machine that is used by multiple users safer. This also allows file transfers and it works behind firewalls. It is very secure making use of AES 256 bit for communication security. It also has web based access that you can use while you are on the road. This software can be downloaded here:
https://www.teamviewer.com/en/download/windows/
