What is the graphic submit button?
What is the graphic submit button? How does it work? Where does it use? Please tell me about details. Is graphic submit button is important to web page?
You can use graphic photos to your submit button.
It helps the designer to make the website colorful.
Example:
Here the src is the source of the image file and others attributes are width, height and value.
The graphic submit button is use to get input from user to specific server. You can use a graphical picture for many reasons.
For example after typing First name and last name you have to send same information to server so it can save it.
And a graphical picture is used to uniquely identify it for user. So after giving required information user know which button to press.
example
Top of Form
 First Name  Â
 Last NameÂ
    E-MailÂ
Bottom of Form
source code
