What is grep in linux
Hi Chase Dean,
Grep is a command line in Linux which searches the lines which matches the given criteria in folder or given file. Grep shows the matching lines by default but specific operational modes can be choose. This is a very useful tool to search data from PC even if you don’t know where it is stored. Originally grep was prepared for UNIX but it also works on UNIX like systems.
If you write .mp3 in grep regex, it will search each line of file to find .mp3 and will show the lines containing this so grep is a line based. Search pattern is case sensitive by default so it cant find Cat (with capital C) if you searched cat (with c).
Gep command line
Grep ‘ word ‘ filename
Grep ‘ jaz jaz2 ’ filename
Cat other file I grep ‘anything’
Command I grep ‘anything’
Command optional I grep ‘data’
Grep – colour ‘data’ filename
In Linux, when using the grep command, it searches the specified file for a match to the given words or strings. By default, grep displays the matching lines. Use grep to search for lines of text that match one or many regular expressions, and outputs only the matching lines. Here is the command syntax for grep:
For example, to search /etc/passwd for boo user, you can enter:
$ grep boo /etc/passwd
You can also force grep to ignore the casing of the words by using the option “-i”:
$ grep -i "boo" /etc/passwd
For additional information regarding this matter, you may visit HowTo: Use grep Command In Linux.
