What handheld device is most recommended?
Hi, I was wondering what handheld PDA device is most recommended?  I am looking for something that is easy to use but can carry a lot of information.  I'd also prefer something that doesn't require frequent charging if at all possible.  I appreciate any advice or suggestions.  Thank you.
Answered By 0 points N/A #191540
There are so many PDA(Personal Digital Assistant) devices available  on market. You need to choose the device based on your budget and requirement. In the medium budget I will suggest you to buy the device ‘Palm Tungsten E2’ handled PDA device. The price of this device about $100. It has 320×320 transflective TFT color display and touchscreen. The battery life is moderate for this device. Also it is compatible with Windows 7. But it is not compatible with Windows 8.
Also you can go for ‘Palm Tx’ handheld PDA device. The price of this device about $130.  The screen size is little bigger(320×480)  for this. It has built in wi-fi(802.11b) and Bluetooth. The battery life is very good. It supports external memory card to increase the storage capacity.
