Have you ever had any hard disk problem, CD-ROM player problem, wireless problem, booting-up issue, unfriendly keyboard or any other issues with Toshiba laptop. How would you rate Toshiba laptop in comparison to some other laptop that you have used previously? Should I go for Toshiba and why do you think it will be a perfect choice to buy?
What Hardware Problems Have You Encountered Whiles Using Toshiba Laptops?
Hi Robert.
I used a Toshiba laptop for 2 years and i regret for using that. Now i use Asus laptop. I find a lot good differences. I never had hard disk problems, but i had few problems.
1. Toshiba used to get really hot after a certain time and ASUS is better in that cooling sense.
2. Toshiba is actually good, but ASUS is better in sense of battery lasting. Toshiba battery gets unusable after 1 year, whereas ASUS laptop batteries are quite good. They might be wrong as well, but that is what I faced.
You can always look on the internet.
