What is the resolution in new LG 5.5-inch QHD? Is its LED screen panel? In which model the display will be used? Does it decline any impact on power consumption? What is the difference between percentages of contrast ratio old and new (LG 5.5-inch QHD)? What is UV light technology? Thank You
What has new in LG 5.5-inch QHD?
Hello Adamswhitley!
Let’s eliminate your questions one by one.
1. What is the resolution in new LG 5.5-inch QHD? Answer – 1440 x 2560 resolution with 538 PPI, 120% color gamut.
2. Is it LED screen panel? Answer – it’s LED screen panel, photo-alignment, Advanced In-Cell Touch (AIT)
3. In which model the display will be used? Answer – the display screen will be used in the forthcoming models of LG.
4. Does it decline any impact on power consumption? Answer – though this model provides brighter screen, it reduces and or maintain same power consumption that is the same with the previous model.
5. What is the difference between percentages of contrast ratio old and new (LG 5.5-inch QHD) Answer – the contrast ration is better and improved. You can see better even if you’re outdoor and gives more brightness in dark rooms.
6. What is UV light technology? Answer – UV light is similar to the sun, it decreases the existence of bacteria, lead, chemicals and other dirt as the water is exposed to its active light waves.
