karimsniper
10 points
Posted on - 09/22/2011
I just purchased a new digital camera. He calls you into his office and tells you that the pictures take a long time to transfer from the camera to his computer. Upon inspection, you realize that the camera uses Universal Serial Bus (USB) 2.0, and my computer uses only has USB 1.1 ports.
How can i transfer pictures from the camera to his computer faster?
jackbeen
What is the faster to transfer pic from cam to pc ?
You have bought a new digital camera that using the serial bus 2.0 and your computer using the serial bus 1.0. To faster the flow of data from your digital camera to your computer we have another type of port which speed is about 400 Mbps. Which have IEEE standard name is i394 if you have this port in your computer then try to connect your digital camera through this port it will transfer your data faster from digital camera to computer.
To connect to this port we have a different kind of cable you can't connect through this port using simple USB cable. The cable which is provide connective through this port is given with digital cameras because this port is only used for high data rate from camera to compute. Hope this solve your problem.
