georgewin
Posted on - 08/15/2011
What is the hyper terminal technology provided by windows. I reseached but it is difficult for me to understand without examples. I fond to use different options of the windows. Some one guide me with example. Does this option is useable for me in any kind.
LaraP
What is the Hyper Terminal Technology?
Good Day Georgewin,
Hyper Terminal is tool or program that you can use to remote access / connect to your computer, modem, etc. You can setup up your hyper terminal using WinXP, please see the procedures: Click start menu, click accessories, click communications then hyperterminal, connect using COM1 then click OK button, assign COM1 properties to 57,600 or 115200 bits per second then click OK button, and Hyper Terminal window is already active, you may be able to remote access / connect to your modem, etc.
Please see the links for your reference:
https://www.microsoft.com/en-US/download/details.aspx?id=53314
http://modemsite.com/56k/x2-hyperterm.asp
https://en.wikipedia.org/wiki/HyperACCESS
LaraP
Hi…
So you need to know about the hyper terminal. It is a program; we can call it as a communication program. We can use the hyper terminal to create a connection with another computer through the internet modem.
You can use it as data transferring terminal with the portable device which connected with serial port.
This program was introduced with the Windows 98 operating system. Now it is available with all Microsoft operating systems that came after Windows 98.
You can easily access to this with this path
Start – > Programs – > Accessories – > Communications – > HyperTerminal
This article will help you to setup a hyper terminal connection.
https://www.seetron.com/archive/html/ht_tip1.htm
Thank you….
